You can get USB leads from most mobile phone shops but the cheapest and often easiest solution is...ebay.com
Just type in U600 USB cable and be astounded at how many are available.
On your phone, go to SETTINGS, then PHONE SETTINGS, then USB SETTINGS. Choose MASS STORAGE option from list. Plug in to computer via usb cable. Your computer should detect the phone and install drivers if they are not already installed. On your computer go to 'my computer' and the phone should be listed as 'removable disk (F:)' or another letter. You can then open this disk and view and copy the files on your phone.
if you just want a unlock ,not a full sim unlock use unlock code 1 only.
To Unlock Samsung U600: Unlock Code 1: #*7337# Unlock Codes 2: *7465625*28782# followed with *7465625*28638# Unlock Code 3: #7465625*638*7337#
Entering Code instructions: 1. Take out the SIM card from the phone and switch the phone on. 2. Enter the unlock code into your handset. 3. Now replace your SIM card and turn the phone on. 4. Your handset should now be unlocked.
The quickest way to do this is to put your phone into Mass Storage Mode then connect it via the USB cable to your computer. Your phone shows up as a USB Mass Storage Device and you can select the folders you want to download your pictures from.
To set your phone to Mass Storage Mode, do the following:
- Go to the main menu - Select Settings - Then Select Phone Settings - Choose PC Connections from the menu - And then click on Mass Storage.
When you connect the USB cable to your computer, your phone will show up as a USB Storage device and you can just copy and past files to it like you would a USB Thumb drive. If you select the Samsung PC Studio option...your file transfers will take ALL DAY. Just use Mass Storage mode. Good luck.
first check the usb cord if ok,if ok check the usb port on the phone if ok also if not ok replace but if the usb cord is not ok also replace and thats all that's my solution
