SOURCE: RCA RP5120 Digital Voice Manager
If you bought the recorder new still in it's package, the software is located on the recorder itself.
Plug the recorder into your computer and let the computer recognize it. Once it's loaded open a copy of explorer if one did not open already. Look for a folder named SETUP in the recorder. Inside that folder is the software. Run it from the folder.
This should correct your problem.
SOURCE: Need installation software for rca voice recorder # RP5120.
Here is the link to download it:
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2614
P.S. If this helps you, please use the rating system to rate me!! Thanks!
SOURCE: Need to know how to Manually reset RP5120-A
Plug in your recorder using the USB cable. Copy any of the files you see to your PC. Then reformat the drive. I don't have the exact details for doing this under windows but I fixed the problem this way.
SOURCE: i have rca recorder rp5120-a. i have deleted
Try removing the batteries for 5 minutes then format or delete everything on the recorder.If that doesnt work, send it to rca for service,
SOURCE: My RCA digital voice recorder (RP5120-A) has no
1. Turn on the player. 2. Press ERASE, DELETE will fl ash on the display. 3. Press and hold REC for three seconds, FORMAT will fl ash on the display. 4. Press and hold ERASE, WAIT will show on the display, formatting is in process. • After the formatting is completed, the remain time of the selected memory will show on the display. You may also format the player when connected to a PC (by rightclicking on the player's drive name or letter and select "Format" from the menu). Make sure you select
FAT or FAT16 as the fi le system.
