My 52 sony wega wont turn on. kp-51ws520 just flasing 9 times.
There is a solution posted on the 60" wega. My KDF E60A20 was flashing 6 times. I bought the thermal fuse as suggested replaced it and it worked like a charm. I LOVE THIS WEBSITE!!
From the symptoms you describe, it seems the high voltage flyback
autotransformer has failed along with the horizontal amplifier (they
are slaved to each other). The sound comes from the flyback
unit. I guess it must be a high pitched squeal, actually...
Well,
the only way to solve this is to get a technician take a look at the
set, I'm afraid. Repairs could cost upto $100 or more, depending upon
the number of components that need to be replaced,
Since the set is new, it may be worth getting
fixed up. If you decide to do so, call around, as shops have different
rates and different expertise. Many shops are hurting for work because
so many of the smaller sets are never repaired anymore; they are just
thrown out and replaced since the cost of a new set is sometimes as low
as the repair expense.
Hope that helps...Should you have any further questions,
please feel free to post them here.
P.S. Before you assign a rating, please
make sure that the issue is resolved or you are satisfied. If not, please post
back as to what you did, and/or any other questions you may have, and I will
try to assist you as best I can. Please do not assign an ‘Inappropriate’ or
‘Thanks for trying’ rating if your issue is not resolved after the first
response itself, as sometimes a bit of to and fro dialogue may be necessary
before we can find a fix or an answer to
your query.
If you find that the solution/answer I provided led you
to, or resulted in a fix, please close the ticket with a FixYa! rating.
I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers,
IrishDruid
Just wanted to inquire if your issue is resolved, or if there is anything
further I can do to assist you…
to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
rating under my solution. I would be very grateful for your show of appreciation.
Should you have any further questions, please feel free to
post them here.
Cheers!
IrishDruid
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved."FixYa!"
- The solution provides great advice on how to solve the problem.
(Positive Rating)"Helpful"
- The solution provides useful leads that helps solve the problem.
(Positive Rating)"Thanks
for Trying" - The solution does not solve the problem but the
effort is appreciated. (Negative Rating)"Inappropriate"
- The solution has absolutely nothing to do with the problem. (Negative
Rating)
If your issue is not still not resolved, do not
assign a rating just yet. Please post back as to what steps you took, results,
etc, and I will try to assist you further as best I can.
IrishDruid
If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
i have a 52' big screen sony wega and it wont turn on and the stand by red light just keeps flashing everytime i try to turn it on
Same problem no picture and the stand by mode keeps blinking I did not know so many people are having the same problem most times a good company would issue a recall or send the part to be picked up free at a service provider what is wrong with sony they make all this money from US consumers and now they do not back up thier product.
I will never by a sony product as long as I live
I have the same problem, its such a *******, especially cause i live in a very samll town, with no repair shops. The tv is a 52" so its not easily moved either.
ihave 52 in sony wega red standby light flashes but tv wont come on has done before and we play with it for a while and got it back on but now it wont come on at all just standby red indicator light flashes
big screen sony wega, standby light blinks but tv won't turn on. it's huge and weighs about 250lbs. takes 3 people to move! how can i get it to a repair shop alone? very mad this expensive tv has crapped out on us!
i have Aa SONY WEGA 36 IN. WITH THE PROBLEM ALSO
