Before graphing deactivate the statistical plots: Press [2nd][Y=] to access the (STAT PLOTS) configuration screen and press [4:PlotsOff][ENTER]
To draw polar graph, make sure in MODE, POL is highlighted.
Make sure that the angle unit is set to RADIAN
If you want the angle unit to be in degrees you must open the WINDOW editor to modify the values of Theta max to a significant value: 30, 45, 60, 90, 120, 180, 360, otherwise the calculator will take the default value 6.28 (2*PI) in degrees
