Freezers Logo
Posted on May 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have the Kenmore frost free, 20 cu. ft. freezer, model 2539260411, purchased in about 1995. Usually about 2:15 p.m. daily, the freezer "temp alarm" beeps. It continues to beep until we press the reset button. The temperature in the freezer stays consistantly low, so that is not the problem. Any suggestions? Thanks. Charlie
Robert Moller
Level 3:
Guru:
  • Master 1,524 Answers
  • Posted on May 29, 2010
Robert Moller
Master
Level 3:
Guru:
Answers
1524
Questions
Helped
579936
Points
4327
Have upright frost free freezer alarm is going off about once or twice a day.Put a thermometer it is around 20 degrees I mute the al;arm and it beeps again and again after several hours. looked to clean...
Hi most deep freezers operate at 0 dergrees. your model may have 2 temp zones. 0 or 20 deg.I'm gessind that your sensor is going off when the defroster is on to melt ice (defrosting). Lower the setting. monitor and repeat as needed. if it continues you may need to replace the unit or ad freon. If the unit is over 13 years ge a new one.
2helpful
I lost the key for door of my kenmore frost free commercial freezer where can i purchase the key?
Hi, here is the replacement key for your model, you can purchase it for $ 2.65:
KEY (Freezer Door Key)
To buy the part call toll-free at 1-888-895-1535 from 7:00 AM to 9:00 PM Eastern time, Monday to Friday and Saturday from 8:00 AM to 6:00 PM Eastern time. Mention part PS426673 (Part Select Number).
Good Luck
1helpful
12 year old freezer won't get above +20. Could it be the temp control dial?
I think you meen below 20 . Its mostlikely low on freon. if only half or less of the evap coil has frost , you low on freon. Then you have a leak in the system.
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
2answers
Kenmore 13.7 Frost Free Freezer
You may want to check the compressor area of the unit.There may be something on the coil or fan blade.(Packing foam,paper, etc)
1helpful
Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
