How to remove outer fairing on FLTR Road Glide?
SOURCE: How do you remove the fairing on a 2009 FLTR SE3?
There usually are additional fasteners that can be found when the headlight assembly is removed, I have an older model and there are four nuts on studs that are attached to the outer fairing tightend onto a frame work between the two halves. Once these are loosened the front assembly slides forward.
SOURCE: removing the fairing from my
Four screws 2 screws on in front of brake lever and clutch lever 2 on bottom under the fork tubes turn the bike to the left to get one out turn to right and get other one out leave headlite in as you remove it unpluge it from bulb MOPAR KENNY
