Cambridge Soundworks SWBL SoundWorks PC multimedia speaker system Speakers - Computer Speakers Logo
Posted on May 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I found my ten year old pc works cambridge soundworks computer speaker system. Without power supply cord and adapter. It says 12 volt at the socket for the power supply. Could I put in other power supply? What specs. should I look for?
Anonymous
Level 2:
New Friend:
  • Expert 62 Answers
  • Posted on May 25, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
62
Questions
0
Helped
19082
Points
138
1st make it sure the volts of your speaker...buy same volts power supply according to you speaker ..
example: 12v 1.0 ampere safe...
1helpful
I need circuit diagram for Cambridge Soundwork Slim 500 model. Where I can find it?
    Cambridge Soundworks circuit diagram cambridge audio a1 ...
    www.fixya.com > ... > Tags > circuit diagram cambridge audio a1 mk3
    Ask your Cambridge Soundworks circuit diagram cambridge audio a1 mk3 questions. Get free help, advice & support from top Cambridge Soundworks experts. images for circuit diagram for Cambridge Soundwork
Service center philippines
I am going to guess these are fairly old speakers. I would recommend getting a replacement system.
Replacement part or schematic for Cambridge Soundworks computer speakers
I'm in the same predicament! I found this - it seems close, though the pins seem to be spaced closer together, but it looks like they might be bent to fit the wider PC board spacing. The rotating shaft also seems smaller - the original is larger than 1/4".
What do you think?
1helpful
WHere do i connect this sound system to as i haven't got instructons?
Connect the power to the power board that supplies mains power to the computer.
Connect the audio input cable from the speakers to the audio out socket on the computer, this is the green socket on the computer.
Cd won't go into the cd slot on the Soundworks--any suggestions?
As far as I know, SoundWorks speaker systems don't have a CD slot. Why would they?
They're supposed to be connected to a computer, which has a CD/DVD drive.
What ac/dc adapter do i use with the creative
check this one, they have power adapter for cambridge soundwork dock
http://www.findpowercord.com/ac-dc-power-adapter-for-cambridge-soundworks-i-dock/
No volume
do they plug in with a 3.5mm audio jack?
if so, i think you need to check your drivers for laptop output socket.
have you tried output with any headphones etc? do they work on laptop?
1helpful
Cambridge soundworks speakers
Happy Holidays Fredonna
Well, easy task, just put a music CD, on system and if you got an headphones, put in the green connector on your sound card, pop up the PC volume, and see if you heard sound, if you do, heard sound then the problem is your speakers. if don't is your sound card.
good luck
2answers
Speakers working, then suddenly not...
It's possible they've died, have you checked that your sound card and drivers are working by using another set of speakers or headphones.
Top Cambridge Soundworks Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
