Re: What does F20 mean. this us\ally happens during the...
As far as i can remember f20 means an outflow problem. On whitegoods.co.uk all machine faults are explained. Error codes can be quite vague and f20 could mean your pump has stopped functioning, you outflow pipe is kinked or you have an internal blockage.
Whirlpool error code F20 appears when no water is detected entering the machine or if the pressure switch trip is not detected. The pressure switch is the part of the machine that monitors high water pressure. The washing machine automatically cancels the wash cycle during an F20 error. Wonder if it has additional issue since it won’t stop quality Appliance repair Stuart Internet answer.
Reasons for error F20: (Water Inlet Problem-no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle Unplug washer or disconnect power.
Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
If that does not help inlet valve, pressure switch and control module must be tested. The defective part must be replaced.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Well the error F20 on display means (Water Inlet Problem, no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle Unplug washer or disconnect power. You can please check the following - Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Post comments for further help or information..........
“F20” on display (Water Inlet Problem—no water or insufficient water supply)
Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
“Spin” and “Wash” (HT “Rinse” and “Cycle
Complete”) illuminated or “F20” on display
water supply)
