My hitachi nailer is not firing. Sounds as if the air is just passing through the gun. Should I change all the o-rings or is there something else I need to look at?
This sounds like the nailer is not in the "home" position. Usually this is due to a leak in the o-ring or a lack of lubrication that is not allowing the plunger to return to the home position. If you can get an O-ring kit, I'd replace all of the orings and make sure that everything is properly lubricated. Should that not fix the problem, the next likely candidate would be the trigger assembly itself. The O-ring kit will run about $20 or so and a similar amount for the trigger assembly.
Hope this helps,
Dan
