Question about Samsung DVDR120 DVD Recorder
Record dvd player to dvd recorder to tv
How do i wire to record from dvd player to dvd recorder
    President:
  • 1,285 Answers
Take the dvd player plug white,yellow & red (line out) & plug these 3 wires into L1 or L2 in on dvd recorder (note on the recorder you must switch the channel from ch3 to either L1 or L2 to record from the player)....... now place the dvd you want to record in player & a blank dvd in the recorder.......press record (recorder)/ press play on (player)
feel free to rate the help
Posted on Aug 22, 2010
SOURCE:
Recorded dvd's wont play on other dvd players
some dvd players (outdated)..will not play these new dvd (recorded or pre-recorded dvd)...if you are recording dvd and wish to play on another dvd player (dvd player must be at least 2009)...same thing happen with my toshiba recorder...my jvc player works its (2008), but my sony dvd (2004) did not play any of the recorded dvds (only the store brought).....suggestion buy a not expensive dvd player (you just need it to play all that other features will push the price range up)
hope this help
May 30, 2010 | Funai PY90VG DVD Player/VCR
My DVD player/recorder, records color but plays black and white
Check in the menu to see if there is a function where you can change from ntsc or pal,you need to be on pal
Oct 29, 2009 | Televison & Video
Can you record a dvd from vhs on this system ?
No you cannot - This is a DVD *PLAYER* / VCR combo - which means it features a DVD player & VHS recorder in one - you cannot record onto DVD - You can however watch a DVD while recording your tv program on the VCR.
I hope this answers your question.
If you want to convert your VHS to DVD you will need to purchase a standalone DVD recorder - I personally do not reocmmend the DVD recorder / VCR combos - or you can use a HDD/DVD recorder which stores recordings on a hard drive and later you can burn them on DVD, they allow editing, more flexible recording options, etc
Aug 17, 2009 | Toshiba SD-V291 DVD Player/VCR
How do i connect dvd player to dvd recorder
you need a tri-color (red,white & yellow) rca cable wire w/ gold tips.....either on the front or back of dvd-rec ....connect wire to the in (line 1 or line 2) coming from the play out on the dvd-player....your dvd rec is still connected to the tv right...on the dvd rec using remote select line 1 or 2 which ever is connected...(test..by playing a dvd in the player..if you see the picture plus hear the audio this means its connected correctly and can be recorded)...note some Disney dvds are not recordable...hope this is helpful.............feel free to rate
Jun 14, 2009 | RCA DRC8300N DVD Recorder/VCR
How to record dvd in ordinary format?
I will presume it plays back fine on your dvd recorder.
In this case, you need to "finalize disc" for it to be playable on other dvd players.
Also, possibly, If you are using a dvd-ram disc, you must make sure that the dvd-player you are trying to use even supports dvd-ram. Most will NOT.
Also, Make sure you are not recording in VR mode. Only some very new dvd-players will support VR mode discs.
Jun 01, 2009 | Pioneer DVR-550HS HDD Recorder
CONNECTING RECORDER TO TV AND DVD PLAYER
I have the manual for this ;asking around 7.50 with free shipping, call if interested 2095683327.willing to drop price a little.
Apr 02, 2009 | Cyberhome DVD Recorder - DVR1600
Adding a dvd player to my dvr and older tv
leave coaxcil cable on dvr ;unplug the colored wires from the dvr output and plug them into the output of the recorder;plug a second set of colored wires into output of dvr and into input of recorder;be sure to set recorder input to proper setting on recorder (input one or two) now you should be able to record what your dvr plays or just use it as a dvd player ; you will need to have all three on to watch tv though.
Mar 01, 2009 | Cyberhome DVD Recorder - DVR1600
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Samsung DVDR120 DVD Recorder Logo
367 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
