Some Pure-Fi's has a problem charging 2nd Gen Touch iPod, even when proper supplied adapter is used. You can try pressing the iPod further into the connector and see if it stays charging. If not, you can tilt the Touch slightly forward to make proper charging contact with Pure-Fi's iPod connector.
If you only charge your 2nd Gen Touch in your Pure-Fi, or other devices less thick than the Touch, like iPod Nanos, then you can stick a spacer on the Pure-Fi behind the Touch to always properly tilt it slightly forward. Only space it slightly forward just enough to cause it to charge so as not to stress the connector.
Stick-on chair/furniture protectors work good for this. If they are too thin, stick one on top the other till you get the thickness you need. Do not use any thicker a spacer than needed so as not to stress the connector any more than needed to make charging contact Use thinner stick-ons, like double sided foam tape, to get the final spacing you need.
The added advantage to a proper spacing between an iPod and Pure-Fi, is it relieves connector stress when plugging in and using an iPod while plugged in, since the taller Touch iPod cannot tilt backward. If you place your spacer at the very top of the Pure-if back panel, then iPods thicker, but shorter, than the height of your space can also be used.
Hope this helps everyone with this irritating Pure-Fi design problem.
To view the charging/not charging status on the 2nd Gen's screen, turn off the 2nd Gen and the Charging Icon will show when contact is being made.
SOURCE: Will not charge a ipod touch 2
If you're willing to spend $40, there's an adapter available from Scosche Accessories. It comes in both black and white and they say it will convert any docking device to the new charging format. (The problem is that Apple has discontinued charging via the FireWire pin - which virtually all accessories - even including Bose - have used up to now. All the 2nd Generation stuff now uses direct USB charging, not FireWire.
Check out the convertor at:
http://scosche.com/products/sfID1/210/sfID2/339/sfID3/318/productID/1694
Dave
SOURCE: My Ipod touch won't charge, it plays music
I bought this Charge Converter from CableJive. It allows me to charge my iPhone 3g on many accessories that would not normally charge the newer models and has successfully fixed the issue with my H+K Dock. I definitely recommend checking them out.
[cablejive.com]
SOURCE: does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this.
But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock.
If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod)
btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
SOURCE: our sound dock does not charge our ipod touch 2nd
The original SoundDock will not charge the iPod touch 2nd gen, or the iPhone 3G, or the new nano either. This is because Apple changed the way their new iPod products charge. (via USB only now)
There is 1 solution- Call Bose tech support. They can replace the 30 pin metal connector for a new one that will charge this. If this is not under warranty, it will cost $99, but it's worth it. New 1 year warranty, and compatibility with all iPods (except much older- non-clickwheel iPods)
