Its a standard 10 watt 120 volt night light bulb thats found in your bathroom night light and is available at most grocery or hardware stores and home centers,please rate this if it helped you.thank you
If you are going to replace a bulb in your cluster, it is a good idea to replace all of them. Not only will the lights on your Escape be brighter, you decrease the likelihood you will need to change any of the bulbs again in the near future. A burnt out bulb in the taillight cluster of your Escape is an excuse for a police officer to pull you over. Check your bulbs frequently and change burnt bulbs promptly
There must still be some burnt out bulbs. The reason they blink to fast is because the bulbs have a heat-based blink mechanism, and when a bulb is out there is more power going to the bulbs which causes them to heat faster. Double check all the bulbs one by one.
Could be a broken wire at the socket. Sounds like a burnt bulb also. Sometimes a burnt bulb will do the same thing as you are describing. Once you get this fixed, all should work. If flashing to quickly, replace the flasher stat unit!
Hi Legalass, Condensation will be caused by water or moisture entering the head light unit. If the lens is cracked or broken or the cover are not correctly fitted that will answer that part of the question. I think for the second part of the question you should take the vehicle and have the voltage regulator output checked. It is possible that the alternator is being allowed to over charge and when it does, it may be blowing the bulbs! Regards John
First, check fuses. If the fuse for tail and brake lights is OK, check the bulbs. If they are OK, you need a new brake light switch, which attached to the brake pedal under the dash. The part should be less than $20. These are a common replacement item on older fords.
remove the bulb thats out, check the socket it's in for burnt contacts as this is common. if the contacts are burnt check the metal contacts on the tail light assembly, if they are burnt you will have to replace the whole assembly. if they are ok replace the bulb and socket
