I have followed the steps you have suggesed for turning off the CC on the Olevia LCD Flatscreen, and it doens't work. I have followed the steps you have suggesed for turning off the CC on the Olevia LCD Flatscreen, and it doens't work.
I have the same problem - cannot get closed captioning off my tv. I've used the remote to turn it off, or try to, and it doesn't go away.I have the same problem - cannot get closed captioning off my tv. I've used the remote to turn it off, or try to, and it doesn't go away.
AnonymousApr 08, 2009
closed caption will not stay off, I turn it off in menu, it seems off then it comes back after awhile....
Tried everything cannot get the cc tu turn of on our Olevia LCD Flatscreen. It is really annoying.Tried everything cannot get the cc tu turn of on our Olevia LCD Flatscreen. It is really annoying.
AnonymousMay 05, 2009
i cannot turn off my 37" sanyo lcd tv .nor volume and input buttons are working.
by remote control it can be turned off ,all functions are working properlyi cannot turn off my 37" sanyo lcd tv .nor volume and input buttons are working.
You can't post conmments that contain an email address.
Access the TV's menu by pressing the "menu" button on the remote. Look for "Captioning" or if not on the screen try "set-up" or "audio" all the while looking for "CC", "Caption" or "Closed Caption". When you find it, turn it off.
You should be able to accsess your menu by pressing the menu button on your remote. You can scroll around until you see a "CC" option. Select that and arrow up down or side to side to select turning closed caption off.
Go in ur tv menu go" Picture" go down to reset, press it the tv will back to factory setting.If the Captioning still there.Than ur Tuner Main signal board have problems.
On the TV's user menu (press "menu" button) look for "Captioning" or "Closed Caption" choice. If not immediately in view look in "set up" or "Audio"...it should be in the menu. Find it and then turn it off.
Try pressing the "View" button on the remote control a couple times -- it sounds like you have the picture-in-picture mode turned on but with nothing showing on the second input.
You have the CC (closed captioning) turned on and it is set to text mode. Look for a button on your remote labeled "CC" or go into your TV menu and make sure the captioning selection is set to "off".
