Connecting your old RDR-HXD890 player/recorder to your Sky Q box and TV can be done by using the appropriate cables and connections. Here is an example of how you can connect the devices:
Connect the HDMI output of the Sky Q box to the HDMI input of the RDR-HXD890 using an HDMI cable. This will send the video and audio signals from the Sky Q box to the RDR-HXD890.
Connect the HDMI output of the RDR-HXD890 to the HDMI input of the TV using an HDMI cable. This will send the video and audio signals from the RDR-HXD890 to the TV.
Connect the aerial cable to the aerial input of the RDR-HXD890
Connect the RDR-HXD890 to the power outlet
Turn on all the devices and set the TV to the HDMI input where the RDR-HXD890 is connected.
By connecting your devices in this manner, you will be able to watch and record TV shows and movies from your Sky Q box through the RDR-HXD890 and display them on your TV.
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
scart can only support 1x video signal and 1x L and 1x R in one direction if you have a scart cable with more than 3 cinch connectors then you have one for two way, but you want to send 5 audio and 1 video channel one way from sky box to your receiver.
looking at the spec, your receiver does support a digital coaxial connection ( cinch orange) and a digital fibre connection it also supports composite 5.1 analogue connection which is where are most likely already connected. it does not seem to be a HDMI device. if your sky box also has digital coax or fibre I recommend using one of these alteratively if you wish to use analogue input on your receiver then ensure your topbox has corresponding 5.1 cinch connectors. usually labelled (center, front,surround and possible also subwoofer)
if your receiver can generate 5.1 from 2.0 stereo (dolby pro-logic II) then ensure this setting is selected on your receiver.
not knowing what your sky box details are I can not say what is the best option. also check that your sky box is sending 5.1 signal out as some programmes may only be being sent in stereo so prologic will have to be activated to generate 5.1 from stereo.
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
I have the same amplifier, a Sky + HD box, an LCD TV an surround speakers. We wont go into the Wii, PS3 and PC also hooked up. Essentially the best way to go (whatever you connect up) is to split the video and audio signals.
Sky: The Sky box has an audio outputs (left and right channel) found at the back of the box. You get some twin audio cables, plug into the back of the Sky box and the other end into the Kenwood Amp (for example we use Video 1). This means that the sound from Sky can be found on Video 1 on the Amp.
You take the video signal (picture) from Sky using a SCART cable and put into the back of your panasonic TV. This does mean that you can watch a picture without the sound and listen without a picture. The Amp remote controls the sound, the Sky / TV remote controls the picture.
You may need to tinker with some settings on the Amp, for example on the front of the Amp you will find a source button, toggle through the 3 or 4 options to give you the right sound. But essentially that should be it. The same process is used for any other things you want to add, like a DVD player, a games console and so on.
I would advise connecting your sky box to the TV with a scart cable or better still a HDMI cable & not the RF cable. The reasons for this sre
1.. You should get a much better quality of picture from Sky
2.. You will not need to tune in the TV just go to the AV or HDMI input source to obtain the sky channels.
If you are not connected to HD, pixelation can easily occur, especially if you are using an analogue connection. Here is a list, from best to worst, of how you should connect the video on your system.
1) BEST - HDI cable between the TV HDMI in and the sky box HDMI out. This is a full bandwidth digital audio and video connection.
2) BETTER - S-Video between your TV and sky box (with L & R audio)
3) GOOD - Component Video with L & R audio
4) STANDARD - single video cable (yellow) along with L & R audio
5) standard coax
These are listed, as stated, from best to worst quality. If you are not using a digital connection (HDMI), then pixelation can be expected.
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
