Nokia 5130 c-2 phone uses phone memory as a "virtual memory" to create playlist in the music player. Almost 5MB free memory required to phone to start the music player. If the memory is not there then it shows error "not enough memory". To resolve this issue, delete some data from phone memory or transfer it to memory card, when there will be free memory available to music player, this error will not display. You can also easily resolve this issue after formatting the phone memory or restore your phone to "Factory Settings"
I hope this solution helps you Thank you for using FixYa!
Hello Sir !! Welcome to Fixya !! You need to format/flash the memory card to get access back.There is a simple way of flashing a memory card.Put the memory card in card reader and attach it with the PC.A icon will appear in My Computer with the memory card name(usually Memory Card).then follow the these simple steps :
Right-click the drive letter associated with your memory card, then selectFormat.
Select a File system type.
Click Start
You are done.Place it back in your device and enjoy. If it was helpful then please rate or a token of appreciation will be esteemed.
Hi, Unfortunately there's no software to recover the password. but you can format the memory card by putting it in the laptop using a media card reader. however there will be data loss.
If you find this helpful please vote my solution. Please let me know if you need more help:)
You do not have a password to unlock you memory card. The things you should do is to look at you and if you can see a small button you just only slide it to unlock. After that you can use your memory card now.
Hi there, I have a micro sd card from Nokia 5300 phone.But when i use the same card in Nokia 3120 Classic, the memory card has been locked but i did not set any password for the memory card...Can this issue be solved in nokia 3120 classic phone.Can the password be unlocked in nokia 3120 classic.........Please advise.....
As epsiman suggested you to format it ,it will not work since you forgot password and with password a memory card is not detected on any computer,you mst reset the password before.Like below from faq section will give you instructions to reset the password:
