1.) Shut down the system completely, remove the battery, and disconnect
the power adapter.
2.) Press and hold the power button on the laptop for a few seconds.
This drains all the power lingering in your Mac.
3.) Re-insert the battery and power adapter (if you were using it
before), and turn your Mac back on as your normally would.
A laptop computer's webcam camera can be turned off or temporarily disabled for security or privacy concerns.
The method varies according to the operating system you are using.
iSight, for example, is a webcam that is built into Macintosh computers and is accessed through web software.
After you disable iSight it will prevent any web-based software from finding or connecting to the camera.
All you need is administrative access to the computer.
lick on the "Start" menu in the lower left corner of the screen if you have Microsoft Windows operating System.
Select "Control Panel" and click on "System." Choose the "Hardware" tab and then select "Device Manage.
Look under the menu "Imaging Devices" and locate your camera listed.
Right-click on the camera device and select the disable option from the menu.
Shut off Built-in Webcam on MacIntosh Operating System
Click on the "System" folder on the computer's hard drive. Once in the "System" folder, click on the "Library" folder.
While in the "Library" folder, click on the "Quick Time" folder. Select the "Directory" tab and find the " Quicktime USB VDC Digitizer Component" file.
Form a "Temporary Backup iSight" folder onto the computer's hard drive.
Copy and move the " Quicktime USB VDC Digitizer Component" file to the new back up folder.
Drag the folder to the trash to erase it.
Be careful that you do not erase both files or it will permanently delete it and you will not be able to access the camera again.
Open a web-based software program to make sure the iSight camera is disabled.
Hope this helps
