Linksys WRT160N Wireless Router  Logo
A
Anonymous Posted on May 20, 2010
Okay what happens is when i try to Connect to my Linksys wireless-n Router model: WRT160N it connects fine but the internet is so slow but when i connect to it wired it works fine how can i fix the wireless problem
Anonymous
Level 1:
  • Contributor 59 Answers
  • Posted on May 31, 2010
Anonymous
Contributor
Level 1:
Answers
59
Questions
0
Helped
18795
Points
91
Open http://192.168.1.1 and go tom wireless page and change the radio band and channel both to auto ...
or simly u can use the following as well
Radio band is : 20mhz
Standard channel : 6
2answers
I need to secure my linksys router, please advise. Linksys WRT160N
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Linksys WRT160N router problem
go to control panel--network and internet--n/w and sharing centre---manage wireless n/ws---remove all wireless n/ws u see there including ur n/w name......then click start--connect to---connect to ur n/w typing proper encryption keys
My ipod touch wont connect to linksys model number WRT160N
This router WRT160N has issues with the firmware. It is recommended that you should upgrade the firmware of the router. Download the correct firmware of your router from www.linksys.com/download .
save it on your computer. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Open the set up page of the router and upgrade the firmware of the router.
Once you upgrade the firmware of the router, reset the router and reconfigure the router.
Click here for step by step instructions.
1helpful
I have a linksys wrt160n wireless router,, recently I was unable to connect to the wireless device, I noticed another linksys wireless device showing up on available networks,,I live in an apartment. I...
If not then connect the computer to the router. If you are connecting a wireless computer then disable the wireless connection on the computer. open the set up page of the router. change the wireless network name to something different that you never used before. change the standard channel to 11. save the settings. Try to connect to the wireless network. Check if you see the new network name ? If you see the new then try t connect and see if that works.
Upgrade the firmware of the router. power cycle the router.
Click here for more information about router and network
Linksys wrt160n router. wireless xbox won't connect
I made it an unsecured connection and everything worked. Not ideal solution, but it worked.
Linksys WRT160N Connection Issues.
Sadly, this router has horrible reviews and is known for this problem:
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16833124277
Can you return it for another model?
Can you getLinksys to replace it?
the best one is the LINKSYS WRT54GL, but if you are stuck with the one you have...
If you have tried all these things and you are very brave (or don't care if you need to buy another router) why not try flashing it with an after market O/S?
1) http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
2) http://www.dd-wrt.com/phpBB2/viewtopic.php?t=32576&highlight=wrt160n
Cannot connect wirelessly to my Linksys WRT160n, but wired works
Get Network Magic ... download for evaluation.
This is a tremendous network management tool well worth the $. If you dont pay, you can still use most features.
Get it and use it to get your connection going at least.
Let me know what happens
a
I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem: http://www.digitalhome.ca/forum/showthread.php?t=97732
Setting up a Linksys WRT160N Wireless Router: http://www.linksysbycisco.com/US/en/support/WRT160N
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Serge
Cannot connect laptop to wireless router
probably nothing..go to the maker of your computer, and get a fresh wireless driver set..maybe the old one did not include linksys..it does happen in MSoft land.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
