The experience forgot Windows Vista password happened to me few days ago. And I searched on the Internet to find the solution. Then I found a windows password reset tool called Windows Password Recovery Tool 3.0 has a good evaluation.
I tried it as the steps:Step1:Download and install Windows Password Recovery Tool 3.0Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.Step3:Put in my newly created CD and remove my forgotten computer Password.
It really helpful when comes to reset Windows password an any version.More detail guide on Windows Vista password recovery:
http://www.windowspasswordsrecovery.com/vista-password-recovery.htm
I got this pro video on "Dell Latitude password forgot":http://www.youtube.com/watch?v=WoXOoaXGl...
Follow this 5 easy steps to reset your password:
1. Enter a computer that can link to Internet. Download Windows Login Recovery and install the software on that computer.
2. Run the software and create windows password reset disk by follow the instructions.
3. Eject the created CD/DVD and insert it into the locked computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to reset your password.
5. Now login Windows and set a new password.
1. Use windows password reset disk If you forget your password, you can reset it using a password reset disk for your user account (or the password reset information stored on another type of removable media, such as a USB flash drive). If you don't have a password reset disk, you'll need to get someone with an administrator account on the computer to reset your password for you. 1. If you enter the wrong password when you attempt to log on, Windows displays a message that the password is incorrect. Click OK to close the message. 2. Click Reset password, and then insert your windows password reset disk (or other removable media). 3. Follow the steps in the Password Reset Wizard to create a new password. 4. Log on with the new password. If you forget your password again, you can use the same password reset disk. You don't need to make a new one. http://windows.microsoft.com/en-US/windows-vista/What-to-do-if-you-forget-your-Windows-password 2. Reset or recover password with Spower windows password reset tool 2.1 Download and install spower windows password reset tool. 2.2 Create an usb or cd password reset disk. 2.3 Boot computer from password reset disk. 2.4 Reset computer password with password reset disk.
This all-in-one password recovery software SmartKey Windows Password Recovery will surely help you out. It is capable of resetting forgotten or lost Windows Administrator login password, and recovering lost password for multiple web browsers, mail clients, FTP clients, chat messengers etc. Dell computers are compatible.Details in:
http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
I know a software can recover windows vista password,and I used it before,my friend recommended it to me,it is easy to use,and I do it by myself,It seems called Windows Password Key 8.0.You can have a try.
More detail guide on:
http://www.lostwindowspassword.com/bypass-vista-password.html
Suggesting for someone who forgot windows 7 password:First of all,you need a third part software,such as Windows Password Unlocker.After you get it,you can reset your password now:Step 1: Burn a bootable CD/DVD or USB flash driveStep 2: Set your computer to boot from CD/DVD or USB flash driveStep 3: Remove the forgotten Windows password with the burned
There are some other way to reset Windows password with a bootable CD/DVD or USB flash drive. It is not so troublesome that you forgot Windows password, you can see this article about Windows 7/Vista/XP/2008/2003/2000 password recovery. Two steps:
Reset windows password with "Advanced WIndows password recovery tool"
These tools is to reset the password offline.
1. Create a password reset disk;
2. Reset Windows server 2008/2003/2000 local or domain password offline!
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Forgot Your Windows 7 admin password? Don't worry! I had the same problem as you. when i try to boot up in safe mode, but opened in the same window as before, still asking for my password. This situation can only use the third party software. I solved that with Windows Password Reset 9.0. http://www.reset-windows-password.com/reset-windows-7-password.html
Nearly Two days ago, I found the password reset product Windows Password Seeker which has been recommended at about.com and use it to recover my lost password successfully. It is a very simple and useful tool. Just follow the step-by-step instructions at http://www.passwordseeker.com/howtouse.html
Windows Password Reset 9.0 can help you, You can downloaded it and burned it to a USB memory card. Then to remove the password. Please open this link: http://www.reset-windows-password.com/how-to-reset-windows-password.html
For removing Windows login Passwords safely, I strongly recommend windows password program. Few days ago, I downloaded one at http://www.reset-windows-password.com I burned it to a Usb memory card. Booting up and clearing my password within just 5 minutes
Yesterday, I didn't remember my Windows logon passwords. At last, my workmate Adam suggest Windows Password Seeker. The powerful app help me get back into windows successfully. You could Search windows password seeker or visit their website: http://www.passwordseeker.com
You can create a password reset CD or USB with Windows Password Breaker to reset the forgotten password.
Step 1: Download and install Windows Password Breaker.
Step 2: Burn a password reset CD/DVD/USB with the program.
Step 3: Remove the password with the created CD/DVD/USB.
I think you forgot windows Vista password you set before. You will reset the password as soon as possible to regain access to your computer.
In this occasion, you'd better reset windows vista password with
a third-party program like Windows Login Recovery, download it and
install it in an accessible computer, and burn a bootable password reset
CD/DVD or USB, then you can get password recovery in several minutes.
SOURCE: Forgot password to login to my account on my acer
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc.
3. Third-party software to create a bootable password reset
CD/DVD or USB, like Windows Password Breaker.
4. Re-install. Will lose data.
SOURCE: forgot my windows vista login password?
Once you forgot admin password in windows vista, you can bypass windows vista password with third-party password reset tools, take Windows Login recovery for Example, it is professional software woking for windows vista password reset. You can download it and follow its guide to burn a password reset CD/DVD or USB falsh drive to get your password reset or bypassed.
SOURCE: forgot password for vista login
SOURCE: forgot Dell Windows 7 password
when forgot Dell Windows 7 password, get tutorial to reset password:
http://www.windowspasswordsrecovery.com/articles/password/reset-dell-password-in-windows-7.html
How to access
Windows Vista without reset disk?
Reference to:
Forgot
Windows 7 Password and No Reset Disk - How to Get in?
This passage is
mainly about how to reset Windows 7 forgotten password without reset disk, but
it is also applied to Windows Vista.
Another
administrator, Windows install CD, Ophcrack and Windows Password
Genius can be used to reset Windows 7 forgotten password.
It is not so troublesome that you forgot Windows password, you can see this article about Windows 7/Vista/XP/2000 password recovery. Two steps:
I forgot my password to my acer desktop computer and can't login
i need help i forgot ma email password
