Hoover Nextra HNWL 3136 Front Load Washer / Dryer Logo
A
Anonymous Posted on May 20, 2010
Our hoover nextra optima aa1300 will wash but when it begins to spin it stops the start& delay light will flash
5 Related Answers
Anonymous
  • 146 Answers
  • Posted on Nov 03, 2007
SOURCE: hoover nextra 1200
The machine only allows a limited time for all the water to drain out before it starts spinning. If the is a blockage or obstruction in the drain hose or drain pump, the machine will not allow all the water to be pumped out and it will not spin. Check for any restriction especially under the sink/tub where the drain hose attatches to the drain spigot.
Anonymous
  • 108 Answers
  • Posted on Feb 22, 2008
SOURCE: No draining on washing machine
I am not an expert on hoover - mainly hotpoint...but..
To empty your machine of water reset the programmer to Final spin. the machine should empty normally.
On hotpoint if you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor.
(Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Regards
ginko
Ginko
  • 19396 Answers
  • Posted on Oct 16, 2008
SOURCE: hoover nextra optima HNL 6166
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
Anonymous
  • 1122 Answers
  • Posted on Oct 31, 2008
SOURCE: Flashing stop light
have you tryed unplugging it for 5 minutes to see if it resets itself?let me know-mike
Anonymous
  • 3 Answers
  • Posted on Nov 05, 2009
SOURCE: How do you remove the filter for a Hoover washing
I included a link on Youtube to my Nextra where I show how I clean the filter (watch it from 08:55 onwords). Just remove the kick strip and unscrew (philips screwdriver needed) the little screw on the filter itself, then turn it anti-clockwise but while you're doing this make sure you insert the kick strip underneath to gather the residual water. Repeat this operation 3 o 4 times until the sump is totally empty, make sure you don't let the kick strip fill up too much otherwise you'll be spilling water all over the place, so just turn the filter clockwise everytime you want to stop the trickle of water. It's not too complicated and it won't be too messy if you follow these instructions carefully. Good luck ;-)
1helpful
Nextra6.will only go on 40min wash and only spin on slow spin. checked motor brushes and there fine. is it the circuit board
I have a hoover optima 1400AAA, it began to give trouble with programs, 40 degrees washed at 80 degrees, would not spin or empty, etc, called in a hoover repair man who cost me 120euros to remove the program knob and spray the contacts with Servisol super 10 switch cleaning lubricant, apart from the fact that I am still furious, everyone who has a hoover washing machine should know this.
17helpful
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
15helpful
How do you remove the filter for a Hoover washing machine Optima Nextra Model HNL 6166?
1helpful
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Flashing stop light
Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
