same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Unscrew the crown (the main knob on the center right side of the watch casing), wait until the second hand is at the 12 o'clock position, and pull the crown knob up so that it clicks once.
Press the button below the crown knob repeatedly until the hands of the alarm dial point to the time within the next 12 hours that you want the alarm to ring. Pressing the button once will move the alarm one minute forward. Pressing and holding the button will move the alarm forward quickly.
Pull the crown knob one click further out and turn to adjust the main hands to the correct time, to take into account the time you took to set the alarm.
Push the crown knob two clicks back into its normal position, and screw it into place until it locks.
For Temperature calibration: 1. Pull the crown to most extended position (2 notches) 2. Temp hand moves to a default position 3. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button) 4. When done, push crown to 0 position (I used melting ice water to calibrate and fix to 0 deg C)
For Tide calibration: 1. Pull crown to middle position (1 notch) 2. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button) 3. When done, push crown to 0 position
You need to remove the battery in order to stop the watch. You may have to short the watch's battery terminals after battery removal to discharge the internal capacitor, or just wait until it stops. Next you need to align all of the hands to the 12 O'Clock position. Follow the instruction booklet to do this, by pressing S1(top right button) and holding it until the watch starts to race forward (all 3 hands will move) then you can release it. When the hands reach approx. 11:59, press S1 again to halt the speeding motion. Now be very patient and make brief presses of S1 to advance the hands by one second at a time, until the watch shows all 3 hands at the 12 O'Clock position. When you have achieved this press S4 (Lower left button) for 1 second to confirm. (tedious beyond question)
After the LCD display switches on, set the time zone as instructed in the instruction booklet.
If auto synchronisation doesn't work and the watch moves to 12:03 or thereabouts, then carry out a manual sync, by following the instructions under 'Manual Signal Reception', or wait until the next auto update at 3am.
This is out of memory so bare with me. Push and hold the "set" button as if you were going to set the time. Now continue to push the "mode" button that moves from hours, minutes, date, beep setting, alarm setting, etc. Eventually you will come to the Golf setting which will ask whether or not you want to display it. Select yes, push the "set" button again, scroll through, and voila.
I have an AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
