Ovens Logo
Posted on May 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kelvinator F36 oven door glass measurements
My mother (Staying in another town) have a Kelvinator F36 oven of which the door's inside glass has broken. I need the measurements of the inside glass of the oven door so that I can have it cut to size as the part apparently is no longer available as a spare part.
Anonymous
Level 2:
  • Expert 523 Answers
  • Posted on May 27, 2010
Anonymous
Expert
Level 2:
Answers
523
Questions
Helped
134562
Points
944
You have to get high temp glass or it will shatter
How can I clean the inside of the glass on a Lamont 3400 oven door
Hello, Johnny -
The instructions I found for cleaning the glass inside an oven door are generic and not just for a Lamona brand oven. (You did mean "Lamona" and not "Lamont", didn't you?)
See the instructions here:
https://www.mom4real.com/how-to-clean-in-between-glass-on-your/
Read through the instructions, in full, first.
This is a link to other instructions in video format:
https://www.todayshomeowner.com/video/how-to-clean-inside-the-glass-on-an-oven-door/
Best wishes.
Mar 07, 2018 • Ovens
tip
Range/Stove/ Oven Door Glass Replacement
I see many questions come up at Fixya.com about oven door glass that has broken and how to replace the glass. For many ovens it is a relatively simple task. It will take about an hour for most people, depending on the skill level, and the type of door.
To do this job you should have handy a screwdriver, usually a Philips head medium sized, a plastic tarp, especially if your glass in the door is already broken, and of course the new glass. It is also a good idea to measure the new piece of glass to make sure that it is close in size before taking the door apart.
For your safety, make sure that the power is turned off to the oven before starting this job also. The open the oven door and remove the screws on the inside face of the door. If the door can be remove easily you can remove it, but it is not necessary to do that. Make sure that you place the pieces of the door as they come off and the screws in a place to keep them organized for when you put everything back together.
For most ovens you will find the oven glass held in by tabs, similar to a picture frame. Pull the tabs back to release the glass. Carefully remove the old glass from the frame. If it is broken, be very careful not to cut yourself. Also contain the glass on the trap to make cleanup easier. For many newer ovens, you will have three layers of glass. Do the same process for each layer.
When the old glass is removed, then simply replace each layer of glass and press the tabs back in place for each one. Then replace the brackets or inside pieces of the door, and secure with the screws.
This is how easy it is to replace the glass for many of the ovens.
Another word about broken glass in ovens…..
Many of the people that have broken glass state that it broke after running the self-clean feature of their oven. For many of you this warning will be too late…but for those of you that see this before, be warned!
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Mar 22, 2010 • Ovens
2answers
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
1helpful
The outer oven door glass shattered suddenly how do I change it?
I depends on how old your oven is. If you're lucky you may be able to get a replacement glass. If not take some measurements and see a glass supplier. You will need a piece of tempered glass.
Feb 07, 2011 • Ovens
Inside glass on door cracked how do I take door abort and put in glass.
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
heatman101
1helpful
The oven door inside glass has shattered and I was wondering if and how could I replace the inside glass pannel?
Hi.
Yes it is normally possible to replace broken door glass.
Try the following site for some very helpful information
WWW.YOUTUBE.CO.UK
In the search box enter--REPLACING OVEN DOOR GLASS.
Ther are several videos on how to repair oven doors.
Jan 03, 2011 • Ovens
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 • Ovens
Broken glass door
Depends on the model, check the link below to see if the glass alone is available, if it is not , that means that this is sealend inside the door.
In that case replace the whole door, or the oven wont bake evenly anymore.
See : Enter model number here to find assembly diagrams and parts.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
