Epson STYLUS CX3900 All-In-One InkJet Printer Logo
Posted on May 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson Stylus CX4800 prints blurred pictures
My Epson Stylus CX4800 is printing black fine: however, the colors are double printed and not on top of each other. The pictures are blurred and use two lines to print; some colors on one line, and others offset below the line, like they "run down" on the page. I've put in new cartridges, and it is still printing blurred. Any ideas what is wrong?
Jonnhzz Chan
Level 2:
  • Expert 186 Answers
  • Posted on May 24, 2010
Jonnhzz Chan
Expert
Level 2:
Answers
186
Questions
Helped
90830
Points
634
Ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
Enable epson stylus CX4800 to only recognize black cartfridge and not color ones
Did you use Epson Genuine Cartridges?
for the Color Ones?????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Can't locate how to clean print heads on my Epson Stylus CX 4800
Hello, to clean click on start, then click on printer & faxes, then double click the icon Epson CX4800, until it opens. You will see the printing que. Click on printing preferences then select the maintenance tab.
See below., and hope it helps.
Good Luck :0) HERE ARE 2 DIAGRAMS.
1helpful
Why can't I print black and white when color empty
Because the printer need all cartridges not empty to initialized and printing, scanning or copying.Just replace the empty ink.
Gradually stopped printing, first colors, then black. New cartridges no help.
check all the catridge installed ok after finding the gatridge ok if the problem not solved , then uninstall the printer driver and restart after restarting the machine then again reinstall the printer driver properly
Blurred and fuzzy print quality
i think you use a compatible ink... use genuine ink for epson ok...
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
