Lenovo 3000 C100 Notebook Logo
Posted on Apr 06, 2008
Keybord working haphazard
The keys are working hap hazard. most of the left side keys are work haphazard as if i press m both m&n presses the arrow keys not working and even delete key not working. suggest the possible cause and remedy
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Apr 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
374
Points
6
I know what ur problem is exacally. u will have to spent some money to do so. a part in laptop of yours is broken or stolen. u will need to replace it with a new one. or else u can use on-screen keyboard that is in all windows versions to my knoledge. u can find that in start..>>all programs..>>Accessories...>>Accessibility
use it with mouse and stop using ur keyboard. i had the same problem once.
so.....enjoy:-)
When I turn on either left or right indicator both indicators light up
try pushing the hazard light switch again. what you have is the hazard lights in operation ( both sides indicators working) In normal indicator operation power from the flasher unit is directed to which ever side you select but by pressing the hazard light switch the indicator power lights up all lights.
How do i program the radio to only give audio alerts for the county in whitch i reside? (sarpy county in nebraska
1. Turn switch on side of radio to "ON".
2. Press "MENU".
3. Press "UP" arrow until "CHANNEL" is displayed.
4. Press "SELECT".
5. Press "UP" arrow until you hear the broadcast of your station.
6. Press "SELECT" to save station selection.
7. Press "MENU" to close menu mode.
To turn Weather/Hazard broadcast on again, press "WEATHER/SNOOZE".
Note you will hear only static on the channels not received in your area.
(FYI - channels are listed 1-7 on the left, and corresponding frequency numbers are displayed on the right side of display.)
At This Point You Will Receive Weather And Hazard Alerts Issued By The NWS.
1helpful
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
2helpful
Unlock
First you have to call you provoder for an unlock code. Then:
1 - Switch ON your Sony Ericsson W880i without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
If your Sony Ericsson W880i does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2 & 4. We mean by "Down Arrow" to direct the Jogdial down! In the Sony Ericsson W950i and some other models, the down arrow button/key would be located on the side of the phone.
7helpful
2answers
I got eee pc 900a but wireless not working i try
  1. Turn off your computer
  2. Turn it on and immediately begin rapidly pressing F2 by itself
  3. Go to the Advanced tab by pressing the right arrow key once
  4. Go to onboard devices configuration by pressing the down arrow key once, then pressing Enter
  5. Go all the way down to Onboard WLAN by holding down the down arrow key until it is selected
  6. Press the minus key (-)
  7. Press F10
  8. Press Enter when it asks you to save configuration changes
If that still doesn't work, make sure you have the drivers you need from here:
http://support.asus.com/download/Download.aspx?SLanguage=en-us
Keys on left side of keybord do not work
if you have a laptop with special keys left of the keyboard, you may need to install drivers and or software for them, look for them at the makers website the the brand and model of the laptop or keyboard.
if its a special keyboard look for its drivers and software at its makers website.
also if after all that the problem is still not solved make sure hid input service is enabled.
info on the service:
http://www.theeldergeek.com/hid_input_service.htm
how to turn it on or check its status
press the windows key and R key at the same time or windows key first and then r.
in run menu write in services.msc
presss ok or enter
in services look for HID input service or similiar make sure its started, right click on it and select properties make sure its set on automatic start up and start the service if its stopped with the start button. Apply, close ok. should work.
65helpful
Need instructions for Ingraham model TE109
To set the timer press the right arrow key.
The timer will now be blinking 1on.
This means on time for program 1.
Press set.
The days of the week will be blinking now.
Use the arrow keys to scroll through the options, like
just one day of week, every other day ETC..
Press set when you get what you want on the days.
Now the hours will be blinking.
They start at 12:00 AM, so to go to 1:00 PM you would have to
press the arrow key 13 times.
When you get the correct hour, press set.
Now the minutes will be blinking.
Choose the minutes you want with the arrow keys and press set.
You will be back to 1on blinking.
Now press the right arrow key to go to program 1 off.
Set the off time the same way you set the on time.
After setting the off time, or any time 1off is blinking, by pressing the right arrow key you will go to 2on and so on.
You can scroll through all the programs by continuing to press the right arrow key.
Both arrow keys work i.e. you can go backwards if you went too far.
You can go to program 20 off if you press the left arrow key.
Keep pressing the left or right arrow keys to skip to the program
you want to change.
When you get to the program you want to change, press set
Keypad
check tour keybord conector and cable.It will be work fine.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
