Vtech V Tech Kidizoom Camera Logo
Posted on May 24, 2010
My Grandaughter dropped her camera into the bathtub and now doesnt work is there a fix for this?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3809
Points
Yes *** in her mouth and vid it
  • Anonymous May 24, 2010
    sorry (UM in her mouth
Drop in bathtub
people like to enjoy long, hot soak in a bathtub after a long day after work, having a proper bathtub is a must. When it comes to choosing what type of bathtub you would like, there are multiple things you need to consider.
If you have a smaller sized bathroom,
A Drop - in tub will most likely be more beneficial for space saving.
  • Drop - in bathtubs are usually lower priced .
  • You can easily have a shower head without extra plumbing hassles.
  • A drop - in tub allows you more space in your bathroom.
  • Designed with lower sides making getting in and out easier.
  • Can be fully enclosed with minimal construction.
  • Easier installation if you want a whirlpool tub.
  • Typically easier for bathing small children.
The choice of having a bathtub reflects your consciousness towards your bathroom and precise health.
And when it comes to Drop in bathtubs,
"The American Standard Evolution Bathtub"
is entirely different, universal and better fits for your bathroom.Having 21.5 inches in depth, this bathtub allows you to enjoy at least 3 inches deeper soaking bath in this bathtub. The drainage system is quick and even. American Standard Evolution Bathtub has reversible drain outlet which cleans water fast.
Read the full review to get a holistic overview including features ,specification,pros and cons.
hydro-systems-customized-bathtubs-hydrosystems-with-drop-in-bathtub-relaxation-drop-in-bathtub-nvu2yxrtj1tcjm5kl0oggpyr-5-0.jpg
May 11, 2016 • Home
I dropped my phone in the bathtub and the only thing that's wrong now is there is water vapor in my front camera, how do I fix this?
Hello Faith, I don't know if this works for cell phones, but I have heard that you can dry out a wet hearing aid by putting it in the refrigerator for a day or two.
Apr 02, 2015 • Cell Phones
1helpful
2answers
Shutter button wont work
Something has bent or come a drift, not something you can fix yourself, take to camera repair shop for repair , first get a quote as repair may cast as much as a new camera .
Dec 24, 2014 • Cameras
I dropped my fujifilm finepix av100, the lens is now stuck and will not go back in when i turn off my camera. when i turn on my camera it says ''turn camera on and off'' but it doesnt solve the proble
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
1helpful
Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
My kid dropped a 4 inch length and i inch
use a snake if that doesnt work take the toilet off and look in the bottom you should see part of it
Kodak easyshare c340
Oh dear, digital cameras are really very delicate piece of item. Now, since you have dropped the camera, the shock it got from the impact has permanently distorted the Pixels Formation.
I cannot guarantee to fix this problem but you can try to restore the camera by going into the settings > restore default.
If it doesnt work then you can try to alter the images after you transfer them on the computer. lemme know if it worked.
4helpful
4answers
How to fix my camera
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
1helpful
Lens is stuck
Hello Gruntny, in order to repair this Camera you will have to replace the OPTICS UNIT (ED13A). Please contact your nearest Sony Service. Best regards, Arpad
Top Vtech Toys Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Vtech Toy Expert? Answer questions, earn points and help others
