The single most cause of no motor output is failure of the DC motor control Look for any test lights on the power boards beneath the motor shroud use caution when removing the motor hood because you may still have electricity in the motor area even if the treadmill is unplugged.
One of the lights should be labeled PWM when hitting the start button that will start flickering , because the upper console is sending a signal to the lower board telling it to start the motor. if that process happens then you need to check the motor
Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH.
Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery. If does move then the controller board needs to be replace.
ERROR
CODE # 7
E7-
1) Alternative Elevation Motor
1)Cause:
Elevation Motor not moving Solution:Check
Elevation Motor connection
2)Cause:
Elevation Elevation Motor screw binding Solution:
Clean screw and lubricate
3)Cause:
Elevation Motor Motor out of Range Solution:
Check motor out of elevation
4)Cause:
E-Motor Potentiometer: Solution:
Replace Elevation Motor
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
On/Off switch Solution:
Test unit is turned on b)Cause:
Insufficient Power Source Solution:
Plug
dedicated120V, 20Amp Outlet
c)
Cause:
Line
Cord Damaged Solution:
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
Version:1.0
StartHTML:0000000168
EndHTML:0000003648
StartFragment:0000000468
EndFragment:0000003631
The
Steps for Newer Style Console Calibration
Locate the calibration area on the
rear or underside of the console (a hole, near the console's center,
that goes through to the electronics board. (This hole should not
have a screw in it.)
Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click
when pressed).
Press the button 2 times
(with the pencil eraser). The first click should show CL11
in the console, the second click should show CL21.
If the process was done correctly,
and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons
on the console and observing settings. This will not require
any other tools.
Press ENTER. CL22 should display
in the TIME window and (??) in the SPEED window.
Press ENTER. CL23 should display
Press ENTER. CL24 should display
Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
Press ENTER. CL26 should
display in the TIME window. You should then see the
letter "E."
Press ENTER. You should see "SS"
or "55" in the console.
Push the STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill.
Push the ENTER button. The walking
belt should start to move, accelerate to maximum speed, then stop on
its own.
When the belt stops, the
incline should self test by raising to its highest
incline position, then lowering back down to its lowest
position.
Once the incline test is complete,
push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
The
when pressed).
any other tools.
letter "E."
treadmill.
its own.
position.
"F" appeared
in). Troubleshooting the failure would be the next step.
