40 in polaroid flat panel (lcd) is flashing / flickering non stop and making a low popping sound.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
A common problem for these is bad
capacitors in the power supply, Remove the back from your Tv and look at the
power supply on the left hand side.
You will see roughly around 9 x capacitors that
are bulged / domed shaped on top usually these are valued at 3300uf 10V any
that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being
sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a
higher voltage.
Hope this helps
