You could install a filter in the line between the antenna and the transciever. I reccommend a high-pass or band-pass filter set for the 27 MHz band to remove any interference at different frequencies. Also, some older TVs can cause interference to CB radios if they are close. If this doesn't work, the radio may be poorly sheilded or your area may have implemented the broadband power line initiative (BPL). This produces a strong buzz of noise that obliterates all weak to moderate radio signals between 2 and 80 MHz (CB being at 27 MHz).
