Chage the the charging quail
It could be your charge port. Does the phone ever show it's charging and then not charging when you wiggle the port at all? If so we fix charge ports on ebay...just search for "blackberry charge port repair" on ebay and look for the listings with PORT REPAIR written in red around a picture of a charge port. Our ebay user id is "its-a-pheo" You can also ask me any more questions at [email protected]
SOURCE: my new battery to my blackberry will not charge
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues, like charging issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
SOURCE: Issues charging using USB and Computer
solution is to install only USB driver, so that
PC recognizes the Blackberry correctly, and can also charge the device
accordingly.
Try and download usb driver for windows xp or windows vista
SOURCE: want to unlock my verizon blackberry storm
Hi, just call your verizon provider and make request for blackberry storm unlock code or if you want to save more money and time you can purchase reliable blackberry unlock code at third parties sites.
