American Bath Factory La Palma Sistine Stone Raised Drop-in Sink with No Fa Logo
A
Anonymous Posted on May 21, 2010
How do I get the haze off a newly grouted tile flo...
Ned C Cook
Level 3:
President:
  • Master 3,433 Answers
  • Posted on May 26, 2010
Ned C Cook
Master
Level 3:
President:
Answers
3433
Questions
0
Helped
1438168
Points
9966
Let it all dry. Then just buff it off.
1helpful
3answers
How to I clean the grout on my kitchen floor?
There are many ways to clean stained grout. You could try one of the commercial cleaners sold on the market and scrub it with a brush. You can also try creating your own cleaning solution. This way you will avoid using harsh chemicals in your home, which is always a good thing. You could try making a paste of baking soda and some water and use it to scrub the grout with, or you could spread some baking soda on the grout and then pour some vinegar on it. After about half an hour you should be able to scrub off the dirt easily. In some cases the grout is so dirty, that the only option is to remove it and apply new one. You can check the website attached, the professionals there know a lot about tile cleaning and maintenance.
Oct 06, 2015 • Vacuums
tip
Ceramic tile installation
To Start a Ceramic Tile Project:
1st: Figure out the Size of the Room-Length x Width. This will give you the suare Footage of the Room, and will Determine the amount of Materials You will need for Preparation of Floor before Tile Installation.
2nd: Pick out the size of Tiles, and the Color you wish to Purchase(Decide if it is a High Traffic Area) Tile Comes in different Grades, and if a High Traffic area, you will need a Higher Grade Tile.
3rd: Materials needed for Preparation- Hardy Backer Board(1/2"-3' x 5'). HardyBoard Screws, Unsanded Mastec, Spacers-Depending on Tile Spacing/size of Tiles, 1' x 4' boards. (Tools Needed- Drill, Chalkline, Measuring tape, 3/16 x 3/16 Trowel, 1/4 x 1/4 trowel).
Installation; )Preparation) 1- Apply a 3/16 x3/16 trowel of Unsanded mastecon floor before laying the Backerboard. Screw the Backer Board to the floor recessing screws. (Never have Backerboard meet with 4 pices meet together, off set each piece of backerboard during Installation). After sweeping the room, use a trowel to fill screw holes with unsanded Mastec. Tape all Joints and fill with un-sanded Mastec.(Let Dry for 24 hours).
Tile Installation:- 1st- Sand Mastec used for joints, and screw holes. 2nd- Sweep roome very good and vacuum very well. 3rd- Measure each wall to find the Center Point of the room.(I prefer nailing a board down across one side of the line to keep tiles straight, and butt tiles to the board, and put spacers in between tiles). I use a 1/4" trowel to butter tiles before laying. With using Spacers, buttering tiles, laying tiles.( I prefer using a 2 x 4 and tap tiles across with a rubber Mallet to keep all tiles same heigth). Let One side tiles laid for 24 hours. 4th- Then do the same thing with other side of line.
Finishing Project: Once all the tiles are set, and all spacers removed. Mix up color of Choice unsanded Grout, and follow Manufacturers mixture Specs. Use grout Float and fill Spacing between Tiles. Let dry for 15 minutes. Use bucket of Clean water and Big sponge rinsing frequently removing all Grout from Tiles. Let dry for 30 minutes, and clean tiles again with Clean Water. Let set overnight. Next day, take Clean towel and rub haze off the tiles. Lastly, Seal Tile and grout.
Enjoy your project, and the Satisfaction of doing it yourself. Hope i was some help!!
on Feb 06, 2012 • Ridgid Saws
2answers
How to clean glass tile after installation
Glass tiles can easily be cleaned with a mixture of equal parts of water and vinegar. If you put this solution in a spray bottle, it is easy to apply to the glass tile surface. After spraying, allow the mixture to sit for about ten minutes, so that the vinegar has a chance to work on the hard mineral deposits. Then, a soft bristle brush can be used to not only clean the surface of the glass tiles, but also to scrub the grout.
1helpful
2answers
My newly laid porcelain floor tiles black matt slate effect look dirty after cleaning with water and a cloth. still looks like they have grout residue stuck to them. How can i clean them
Grout residue is removed with an acid residue remover. The installer should have done that--call him back. If epoxy grout was used (not likely) it will be a real problem to remove.
Sep 14, 2014 • Vacuums
How to Grout ceramic tile to shower base
Don't use grout! Instead use silicone caulk that matches your grout color as close as possible. Never grout where tile meets at a 90 degree angle it will crack.
Where does the rubber membrane go when tiling a bathroom floor
tiles on wooden floors will always move and crack the grout/tiling cement
therefore the rubber membrane goes down first with out nails and then everything is laid on top
that way when the wooden floor moves , there is a water proof membrane to prevent the water from rotting the wood over time
Jun 14, 2017 • Home
1helpful
2answers
Hi I moved in to a recently renovated home one year ago. The kitchen had new ceramic tiles installed, with sanded grouted filled in the 5/8 inch joints. I sealed the grout after moving in as I was told...
I have a similar problem. My builder used dimensional lumber for the joists. I asked him if thet would be sufficiently stiff for tile floors, and he said yes. Then after the cracks started, I asked him why the cracks, but he said he didn't know why. It's not necessarily the subfloor but the combination of joists, subfloor, and concrete backer boards under the tile. If you can access the joists under the floor, perhaps you can reinforce them with additional joists or stiffeners before regrouting.
As for me, I have done neither so far. Wife has not complained, so I spend my spare time helping people on FixYa. Like you, I fear regrouting will just lead to recracking, and I no longer have access to the joists. :o(
By the way, your question was sorted as a Harley Davidson question. You weren't riding you bike in the kitchen, were you?
Walk-in shower floor problem
They probably use wrong adhesive that is not hard yet and have tenedency under pressure to squeze out between grout lines. Yes they need to address the problem immediately.
Jan 14, 2010 • Home
Top American Bath Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an American Bath Home Expert? Answer questions, earn points and help others
