Dear Sir, From yesterday in our Sharp xerox machin...
Dear Sir From yesterday in our Sharp xerox machine(model no: ar M205)its continiously blinking H4 and we cannot able to take printout's and xerox.
kindly advice me how to solve this problem.
The Sharp AR-M205 is almost 12 years old now. It will be very hard to find parts for that machine unless you can find a low meter on ebay. You may want to take a look here at some of the current Sharp copier models. It looks like the Sharp MX-M232 replaced this machine.
Duplex model memory error/ Image data error Detail 1. The memory capacity for the duplex model machine is wrong. Insufficient memory capacity. 2. Duplex setting is set for a single surface model.
The Sharp AR-M205 Copier, seems to be Discontinued.I can't find it anywhere. Although you can still get parts and Toner drums for it. This place has it.Sharp AR M205 Copier. $1227!!http://www.digitalsystemcopiers.com/Sharp_arm205specs.html :)
Hello sir; I'm not recognize this model number please double check,but I give you closer one to reset;
1, press "program", "interupt", "clear", "interupt".
2, enter 16 press start.
3, turn machine off and back on .
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
