SOURCE: Replacing tip
i have an old 8200 and i just bend the ends of the replacement tip, then i just tighten the bolts. that is how the tip was on the when i bought the 8200. cheers
SOURCE: Weller 8200 100/140W replacement light bulb?
The bulb's part number is 7333. You can order a replacement bulb here for about $2.50 :http://www.e-sonic.com/aboutus/cat/S/soldering%206.pdf
Testimonial: "Thank you. Bulb voltage is actually whay I was looking for but I did not specifically ask for this.:-) Perhaps a 7333 bulb is a universal #."
SOURCE: I have a older weller
Do NOT attempt to tap out or enlarge the threads. Weller uses special nuts, you can buy a new tip WITH replacement nuts. If you buy the new tip without nuts, you are supposed to bend the two ends 90 degrees, so they fit into the holes in the two cylinders. The tips which are iron-plated will last longer.
