New toro personal pace. Smokes a ton when first initally starting after overnight rest. Sometimes even afer mowing a few lawns it might not start then if let sit for a while will start again
If this is a Briggs and stratton engine, there should be a screw that holds the carburetor bowl. Remove that screw and look for a hole that runs through the middle of the screw from side to side just above the treads. Clean with a thin wire or maybe a paper clip. Then clean the perpendicular hole in the screw that runs from top to bottom. Reassemble and attempt to run. In my experience, if you don't have success at this point, you can buy a new carburetor on amazon for about $20. Install and your good to go.
Sounds like either the gears on the wheels or ends of the trans shaft are bad, or the internals of the trans are bad. Are the parts actually new-new, or used and new to the machine, you didn't specify. What happens when you manually spin the pulley on the top of the trans in either direction?
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
I have a riding toro lawn mower that cut off on me and wouldn.t start back, what could be my problem? The crak wheel trys to turn but it won,t turn over
pull your spark plug and see if it will pull then, if so then it is hydro locked with fuel which can be caused y a bad fuel cap, not venting or a stuck open needle in carb causing gas to flood cylinder
Pull the air cleaner of to see if fuel is getting to carburetor. If it is then see if its getting fire to the plug by taking out and put the wire back on but be careful not to hold the wire or the plug if fire is week then get a new plug or get a new one and see it that helps
