Sony KP-46WT510 46" Rear Projection HDTV Logo
Posted on Apr 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony Kp-fw46m31 Can someone please help me? My sony rear projection doesnt seem to be working. The power lights comes green, then flashes red ten times. Brad
  • 1 more comment
  • Brad_erle Apr 06, 2008
    Its about 5 years old now..... it does blink ten times, then pauses then blinks ten times again and continues to do the same.
  • chapmanins Jun 23, 2008
    Mine also blinks 10 times. I tried to see if it seems to pause in between but i can't tell that it pauses until after the 10th blink. Did you have yours fixed? What can I do? My husband is pretty good at fixing stuff but didn't want to risk messing with it if he didn't know what to look for. Any suggestions?
  • rnstapiki Apr 08, 2009
    Mine flashes green when turned on then flashes red for 10 times too is it fixable
Sonny Berry
Level 3:
  • Sony Master 8,617 Answers
  • Posted on Apr 06, 2008
Sonny Berry
Sony Master
Level 3:
Answers
8617
Questions
Helped
1721888
Points
23750
Count the flashes again carefully, as that model should only blink a maximum of 9 times, unless your getting two seperate codes. Try counting and trying to notice if it pauses a second before blinking again. then let me know what you discover.
  • Sonny Berry
    Sonny Berry Apr 06, 2008
    It has to be power supply most likely stand by supply. I would check the regulator transistors first along with the horizontal out put transistor. Your set isnt going into protective shutdown so it has to be something in stand by or the start up circuits.
A
Anonymous
If the standby led blinks 10 times (HV protect) it will be IC8002 is faulty.
Red out of place on a sony kp51hw40
red and green lights repeat but tv not start
I have no picture and the power light flashes green and then red.
I can help you to solve your Sony tv problem.
Is it Sony KP-51HW40 tv or any other model?
How many times red light start blinking after three seconds long pause?
Let me know to proceed, can you check voltages with multimeter in tv circuit board?
Thanks.
1helpful
Convergience doesnt seem to work. red,blue and green are seperated. like 3d
Did you use 'flash focus' at least 30 mins after starting and let it cycle through?
58" Sony HD Projection
go to wwwsomelifeblog.com/2007/06sony-projection-tv-red-line-repair.html
1helpful
KP-57WS500 turning green or red and then off
Green and Red guns seems defective and requires replacement.
Both guns (CRTs) are no longer available so TV has no worth to repair.
5 flashing light code
Disconnect RED Tube CRT board if set plays without shuting off RED tube is bad or video IC on CRT is bad.
1helpful
Sony KP-FX43M31
On the Sony FX43 100Hz 43-inch rear projection TV, three flashes indicates an Over Voltage Protection problem, occurring in one of the power supply circuits T603 or R672.
The fix will most likely cost more than the set is worth second-hand, I'm afraid.
1helpful
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Kp-57hw40 screen goes bright red or green then powers off
http://esupport.sony.com/perl/news-item.pl?news_id=24
heres a recall of sony hope it helps.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
