Televison & Video Logo
Posted on Apr 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Schematics for toshiba 42hp83 - Televison & Video
  • Anonymous Mar 20, 2009
    i need a copy of the schematics for the same model... if you could send me one it would be greatly appreciated. my email is [email protected]
  • Anonymous May 11, 2010
    Hi my name is Aleixo, I have in my bench one Toshiba 42HP83. I need service manual, if you have it, I would licke one copy if you can. Thank you
Anonymous
Level 3:
Genius:
  • Master 1,153 Answers
  • Posted on Apr 05, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1153
Questions
0
Helped
324834
Points
2386
Do you have email add.?
I have a 42hp83 toshiba tv n when turned on i get pixils at bottom and blotchy pixils all over screen..
Check the connections to the TV, try to double check if the input source is good and does not carrry any video noise. the next thing would be a fault within possible with the drive, a screen failure or a processing fault..
I have a toshiba 42hp83 that is getting no power whatsoever not even a stand by light.
Check ur power source?Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the replacement.
Screen went black and power light flashing on a Toshiba Plasma 42HP83
MAYBE POWER BAD POWER UNIT PART NO:
Manufacturer Toshiba Part Number 23122442 Description POWER UNIT ASSY, P
Toshiba 42hp93
Press the MUTE button twice on the remote control, then press and hold the MUTE button, while pressing the MUTE button press the MENU button on the TV at the same time. This should get you into the service mode Good luck and be careful.
1helpful
2answers
Sound no picture
I have the same problem, did you fix it?
42 in. Toshiba Rear projection HDTV model 42H83
NO picture most offten means HIGH VOLTAGE circuits are not functioning correctly.
which can be caused any myriad of factors.
such as the relay to the high voltage side.
without a schematic you're spittin in the wind.
Green line on each side of the plasma display.
Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
1helpful
2answers
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
