Question about kawasaki Full Suspension Mountain Bike Men
Kawasaki kdx 125 plugs oil up and bike stalls
Kawasaki 125 starts ok but stalls(lack of power) plugs wet and oily bike smells of petrol and exhaust is dirty.suspect carburettor but dont know how to adjust
    Problem Solver:
  • 10 Answers
I think you have worn internal engine parts. To much oil is getting past the piston rings. Try installing new piston rings and honing the cylinder walls.
Posted on Apr 17, 2011
SOURCE:
2003 Kawasaki KDX 220 R stalls when put into gear
Hi, Anonymous and the usual suspects are:
1. Faulty wiring to any safety switch.
2. Safety switches loose at the mounting point.
3. Faulty kickstand safety switch.
4. Failed kickstand safety switch circuit diode.
5. Stretched side stand spring.
6. Side stand not coming up far enough to disengage switch.
7. Faulty clutch lever safety switch.
8. Faulty neutral safety switch.
9. Clutch not properly adjusted.
10. Clutch plates sticking, forward lurch
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike stalls when put in gear
Stalls when putting into gear first time
Kawasaki KDX200 Service Manual
OEM Parts for Kawasaki
2003 Kawasaki KDX220R Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 12, 2014 | 2003 kawasaki KDX 220 R
1996 kdx 200, starts good, boggs out and shuts off while riding like it is running out of gas. any ideas?
my 1998 kdx 200 had the same problem last week. I know exactly what the problem is. My air filter was so clogged with dirt,oil,gunk, that there was absolutely no air or very little mixing with the fuel that it just refused to run. I fouled 3 plugs trying to make it back to campground. I also had black gunk just a dripping from my exhaust which has never happened before, but since it wasnt getting any air it was running so rich. At first i thought that i got water in my carb or fuel lines somehow,cause we were going through some nasty deep puddles. when i got to camp and removed my seat and saw my air cleaner i knew exactly what the problem was. I cleaned out the air cleaner and she ran again...but just like you stated, on the trail my bike acted like i was running out of fuel and just stalled. wish it wasnt when i was doing about 35 but ya know how it goes...i let my bike sit for 5 min, cause wouldnt immediately restart, then it would start. I would make it another 500 yards and stall again. confused i switched tank to reserve, still had plenty of fuel but i was stumped. then eventually i would foul a plug but i always carry 3 plugs even though i make it 2 seasons on 1 plug....so im 99% sure thats your problem....
Nov 30, 2012 | 1998 kawasaki KDX 200
2003 Kawasaki KDX 50 has no horsepower
Hi, Rodgerfaceyi for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2002 JR50 starts runs but no power
2004 Kawasaki KDX50
Suzuki JR50 and Kawasaki KDX50 Service Manual Cyclepedia
http://mybikemanuals.com/kawasaki
May 30, 2012 | 2004 kawasaki KDX 50
My 98 kdx 200 misses when getting into high revs, so it doesnt get to high revs at all, just misses and splutters, even when you in neutral and hold the throttle open just doesnt get to that constant revs,...
Please do not run this bike again... take it to a QUALIFIED PROFESSIONAL and have him clean and set the carburetor!!. Change the transmission oil also. Make sure the exhaust is clean and dry.. UNBURNT fuel in the exhaust is inviting a fire/explosion!!
Sep 29, 2017 | 1998 kawasaki KDX 200
2002 Kawasaki KDX 125 oil type
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere $15 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
KDXRIDER NET View topic Best Transmission Oil to use in KDX200
KDX 200 Uses regular gas without 2 stroke oil draws oil from gearbox
1990 1991 Kawasaki KDX125 KDX250 2 Stroke Motorcycle PDF Download Manuals... $15
2002 Kawasaki KX125 Owner Manual
May 18, 2010 | 2002 kawasaki KDX 125
Kawasaki KDX 125 simple mods to make it better for motorcross
unfortunately apart from removing the lights you wont turn it into a MX bike, new expantion chamber,porting and suspension mods are all quite expensive, just try and learn as much as you can as it is(minus lights)
Apr 05, 2010 | 2000 kawasaki KDX 125
Kdx 200 clutch not engaging properly
The clutch in your bike is a wet clutch. There is a lot of hyrdostatic friction even when the clutch is released completely. I think a large factor is the type, age and condition of oil. Perhaps something as simple as an oil change would help.
Jan 14, 2010 | 2005 kawasaki KDX 200
2001 kdx 220 starts idles great no power stalls out , floods
Use a hotter spark plug. They do have different heat ranges.
Jul 01, 2009 | 2003 kawasaki KDX 220 R
Starts only with new plug,sometimes (1984 kdx)
check engine oil and change the oil seal of engine
Apr 02, 2009 | 2004 kawasaki KDX 220 R
Oil leaks
Don't worry. The bike builds up a little oil at a time.
This is 2 stroke oil that is unburnt during combustion.
You might be running the bike a little rich.
A mix of 32/36 to one is good for outriding.
You should de-carbon the exhaust and replace the silencer packing. This will also give you some unexpected horse power.
Enjoy the ride !
Jon
Feb 19, 2009 | 2000 kawasaki KDX 125
kawasaki Full Suspension Mountain Bike Men Logo
215 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Steve Worthey
Wayne McNeil
Warren Kareroa
Warren Kareroa
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
