Jassy 1103 will not start charging the battery.batteries are two months old. Three fuses ck'd good. Power going to off-board charger is good. Ammeter will not move. Ammeter tested ok with a meter. Note: I still have red lights on batteries. Unit just won't charge.
The 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
