I think this chair uses the VSI joystick controller, and those flash codes are located here: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
SOURCE: I need an instruction manual for a Hoveround MPV 4 Power Wheelcha
Call 1-800-771-6565 extention 5000. You will need the serial number of the chair and then they will get you a manual.
SOURCE: How do I charge the Hoveround mpv 4? I plugged the
Firstly, it is bad news to use an extension cord with the charger as it can get very hot. It will sometimes take 8-12 hours to get a full charge on the batteries. If the light does not go to green on the charger, the batteries may be damaged and not able to take a charge. This is especially true if the Power chair was stored after your father in law died; the gel in the batteries may have gone solid. The lights on the controller will go left to right then back if the charger is connected properly.
The brake release knobs both need to be in the UP/DRIVE position for the motors to engage.
SOURCE: Hoveround MPV 4. Joystick problem?
Count how many lights are flashing to determine the root cause of the problem. Here is alink that may help:
The abrupt stop may have knocked something loose.
