Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Posted on Apr 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost channels hello and thank you ive retuned my sons portable television as some of his digital channels wouldnt work it said to retune it but in doing so ive now only got 1,2,4 and 5 he is very upset and would appreciate u helping me please
Anonymous
Level 2:
Scholar:
  • Expert 131 Answers
  • Posted on Apr 27, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
131
Questions
Helped
19681
Points
285
Make sure when tuning it you have it set to cable you will find that in menu. make sure you have it hooked up to cable. if you dont it will only program channels it sees. you will be able to see it program and tell if it is working.I hope this help
thanks Doctor video
Lost channels, will not install or retune
Check and replace its tuner. It is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
JVC LT22HD32J DIGITAL TV WONT HOLD CHANNELS AFTER RETUNE
It's October 2012 and I have a problem with my exact same model of JVC TV which has worked fine since i bought it in January. In fact it has worked the best out of the four that we have in the house working off the same aerial until 4 days ago. I tried retuneing and then the problem expanded to more channels. I tried to reset to factory options and then do a retune but lost all the channels. I have again reset and retuned and I'm back with channels that I can only tune into for between 4 and 15 seconds before the screen goes blank. None of the other televisions are affected. Digital UK website show no works to transmitters in our area and JVC are impossible to contact. Their site sends one around in circles in a most frustrating and unhelpful way. I will not be buying JVC again. Any help offered would be gratefully accepted!
6helpful
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
1helpful
We have lost all our channels on our humax easy digital 23" lcd Idtv we have retuned it many times and checked all te wires are in place and we still get no channels is there any way to reset the...
Hi, I switch on the humaxand it says -retune. I retune and it finds the channels but will not retain when OK is pressed. It shows the correct postcodebut after numerous attempts it still fails to hold the channels. Please help
Have retuned and have lost Channel 5 (we did have it before)! Newer tv in another room, does have it after retuning. Thank you
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Lost BBC channels on my SAGEM PVR6200T during a retune
Beko 28c723idw has lost all digital channels
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
