Fuse F1 / 250mA fails for no apparent reason. It is on the AC power input circuit board which is under the platter and black plastic cover
http://www.technicsdjuk.com/
Faulty switch? If all else fails go inside! Often from the underside of the turntable and see what you can find.
SOURCE: No Power to 1210s
Problem is not the fuses, but the power supply / power transformer has
blown. This is why you should always wrap exposed wiring with
electrical tape or heatshrink tubing.
The power supply can be purchased HERE,
but this is not an easy replacement. And if you blew it by not properly
replacing the Pop-up light, than I DON'T suggest you try to replace the
power supply on your own either. You could really cause even more
damage, and possible harm to yourself and your property.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
A DJ PRO AUDIO Co.
