The key is removing the gray top cover plate and then it is easy enough to figure out from there. Underneath on the black plate you put the brush into the furthest holes there are screws that are holding the front of the gray top plate. Remove the other black plate like a trapezoid shape on the bottom just by pulling down on the widest part. After removing that you will see four more screws in the clear part hidden deep in holes. Two are just in front of the wheels and then another two about an inch away going towards the brush part. From then it is just a matter of separating the body to be able to remove the part and replace.
Since windows 7 you cant Host a game anymore! The only chance to host and play Hidden & Dangerous Deluxe under Windows 7 is to install VMWare Player and then install WinXP on it (VERY EASY AND FAST, you need a WinXP CD or a ISO file). Then you have to activate Direct3D under the settings of VMWare and it installs automatically VMWare Tools. After this you can install H&D Deluxe on the VM and play the game in full resolution and full speed (fps) without any error!
This helps if you have problems with hosting a game under Win7 with these errors:
Hosten einer Sitzung fehlgeschlagen failed to initialize network connection
Possibly the uninstall has not been complete last time you uninstalled Hidden & Dangerous 2 Sabre Squadron.
Try to run uninstall again and then install. Also delete everything you can inside C:\WINDOWS\Temp and use EasyCleaner... http://personal.inet.fi/business/toniarts/ecleane.htm ...to clean the registry.
If still fails, try uninstall and install in safe mode.
As a final solution. Just do a clean reinstall for whole Windows. For such a great game it is worth it.
I've had similar problems to this, where the computer would start sometimes, and other times it would start, but not give me any video. I changed my power supply and the problem was solved.
