If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
http://www.fixya.com/support/t6088190-hp_7400_displays
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.My officejet 5610 says - 6638622.jpgsrc="/uploads/images/6638622.jpg" alt="6638622.jpg" class="h_mi" />
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open My officejet 5610 says - 6d0bf70.gife access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
Follow the steps given in manual.You'll find the solution at the earliest.
http://office.manualsonline.com/manuals/mfg/hewlettpackard_1/hewlettpackard_1_printer_product_list.html
hope it helps
