Safety switch sticking. Is the cable slack when you let go of the bar? Does it start even if the handle isn't squeezed? If it is and does then cable is frozen or the kill switch is stuck in the open position.
Lube the cable and check the kill switch
Get some WD40 and trace the cable back to the motor. Look at the kill switch assembly and locate the pivot point on the switch where the cable hooks to it. Spray it good then spray the cable at both end letting the lube go in the cable housing. Work handle lever and then see if it works.
