Trying to find out which amp. wiring kit is needed for the AWB-10 Powered Subwoofer enclosure by Power Acoustik.
It has a built in 800 watt amp., with 2 10" woofers, 1 passive, 1 active.
Thank you for your fast response to this question. It was very helpful, as I still get confused with all the technical stuff.Thank you for your fast response to this question. It was very helpful, as I still get confused with all the technical stuff.
You can't post conmments that contain an email address.
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
this amp will give you
1 channel @ 4 ohm x1 350 watts
1 channel @ 2 ohm x1 900 wats
1 channel @ 1 ohm x1 1800 watts
you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you .
i sell this for $320.99 in my store can shipp any where in usa
to contact me [email protected]
No amp is too big, you can turn the gain down. Anyway in my experience people tend to blow up their subs with underpowered stuff anyway (power spikes from clipping). Your amp is rated at 11000watts max and will probably only put out 500 or 600 watts RMS - RMS by the way is the number you should go by. It indicates the usable output w/ out lots of distortion. On the flipside you can power high wattage subs with an underpowered amp and be just fine. However if you wish to extract the most you will need to match amps and subs. A good example of under powered sub applications is in some of my work- I built a wall of nine 12" subs in a bronco, we competed in a 50 watt class and cleaned house taking first in class. Another would be a 150x2 watt amp driving two 15" CV Strokers (1200 watts each). I was going to compete in that class but they made me move up becuase I was an installer at the time. I was upset at first but after my first try I was able to get about 146db and went on to take first anyway. So if the enclosures are built right you can still use that kind of setup. I hope this was helpfull. If you are concerned with exact wattage ratings the manufactures websites should list them. Good luck.
-Dynami
personally i wouldnt use a sony amp for powering anything but,however if your going run it what i would recommend is if the speakers are at 4 ohms then run in series per speaker then put the speakers in series as well so you will keep your 4 ohms then run the amp in mono,however just to let you know that amp will not push fubars enough to really make them thump my advice is to goto http://www.sonicelectronix.com if you have 200 dollars you can get a nice Hifonics TXi 1508D that will push those monsters quite well thats 1 ohm stable and will barley get warm even after hours of thumpage,also if your running subs monoblocks are the way to go hope this helps you out.
Depending on what kind of music you listen to I would say around a 1200 Watt Amp would suffice for what you are saying. Thank you for using Fix Ya! Don't forget to rate the overall answer to your question.
well it is getting hot due to the amp drawing and pushing alot of current. try getting lower gage wiring for power to the amp and lower gage speaker wire.
