Tomtom XL 330S GPS Receiver Logo
Posted on May 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change the language back to English?
Just purchased a Tom Tom XL GPS and once connected to the computer to update map/trip it changed from English to forgein language- have tried resetting, but can not find a way to reset or change the language- please help.
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on May 23, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1184148
Points
12747
In Menu Got to preferences click on flag of language you want
SEE PAGE 35 of the manual
Please rate my help++++Thanks for using FIXYA
2helpful
How do i change the on screen language to english on a tom tom
To change the language, from the main screen tap anywhere on the map. Then tap the wrench icon. Then tap the arrow icon (last icon on second row) 3 times. Then tap the icon with three flags(first icon on top row). Then use the arrows on the right to navigate to the language you want. Once you find it tap the language and then tap yes.
HOW DO I GET MY TOM TOM XL TO THE ENGLISH MODE
  • In driving view, tap the map to bring up the main menu.
  • Locate the "Preferences" icon (looks like a wrench) and tap it.
  • Cycle through the menu pages until you see an icon with three flags (UK, German, Dutch) and tap it.
  • Select English from the list. When you change the language, you are also given the opportunity to change the voice.
How do i reprogram my Tom Tom to the correct language?
First reset your tom tom gps device, that way your language will be back at the default language. To reset your tom tom hold down the power button for about 15 seconds, it will restart itself automatically, that way you will have to chose the language once again. Or you can simply remove the battery and reinstall it in once again. Or you can connect it to a computer and format the gps and download its software back on. That is a sure solution
You can also follow the steps below, but you have to be logical about the position where these options are in the language you mistakenly chose.
  1. Tap the screen to bring up the main menu,
  2. Tap change preferences,
  3. Tap the arrow in the bottom right corner until you see change language,
  4. Tap change language,
  5. Follow the instruction on the screen to confirm the language of your choice,
  6. Choose a voice.
My Dad got a new Tom Tom XL 330 GPS.They changed the language accidentally from english to a foreign language and they don't know how to change it back. Does anyone have an answer for this question? Would...
The simplest way is to have your dad insert a paper clip tip into the "Reset" hole in the gps case. This will set the unit back to factory defaults and it will prompt on startup to select a language.
How do i change the laguage to english please tom tom go 520
The icon to change the language has three flags. Tap that and you will be prompted to select a new language.
1helpful
2answers
Up date maps
To update maps you should run Tom Tom home on your computer and then connect the GPS
It will then ask you if you want to connect to the computer and you would tell your GPS yes.
Tom Tom home will once it finds your GPS then proceed to do any minor updates.
If your map is out of date it will offer you the option of purchasing a newer version.
don't be tempted to look for free / pirate maps !
These can cause problems in starting up your GPS (believe me)
Tom Tom map prices are not too bad and compared to many GPS are quite easy to install using Tom Tom home.
If you don't have Tom Tom home the latest version can be found here.
1helpful
CANT GET IT TO DISPLAY IN ENGLISH
Turn on your tomtom.
When it has booted to the map display press once on the map
Now click the spanner / wrench icon.
Use the right arrow icon to scroll until you see the flags icon and select that.
The language menu will open and you can set it to english there
If english is not listed then it has been deleted by accident and you would have to download it from tom tom to restore it.
13helpful
2answers
Can't change screen to english on my tom tom one
in order to change the language you would need to be at the map on the device. Tap in the center of the map, then tap on the blue wrench or the gear on the main menu. Then you would tap on the arrow on the bottom right until you find 3 flags. Once in there you would be able to change your language.
2answers
Tom tom gps
somehow the language was changed from english to ???? please help
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
