I run castrol 2 cycle oil. stihl oil is castrol oil as well. i use 40;1 in most of my 2 cycle equipment. i like it a little heavier knowing i am getting good lubrication to the motor. good grade of fresh fuel helps alot as well.
16:1 is WAY too much oil if you are using decent synthetic oil. 50:1 will be much better - regardless of what it says on the gas cap. Oils are much better now than they used to be.
Contrary to popular beleif, more oil does NOT help a 2-cycle engine. The oil (which does not burn) displaces fuel in the mixture, so there's less fuel than there should be. That means the mixture is LEAN, and lean mixtures run hot.
Also, check for a partially blocked muffler (likely with that much oil in the mix). This will also make the engine run hot.
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal
2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever
made. You may also use this oil in any other brand of 2-cycle air
cooled equipment, but it should always be mixed at the 50:1 ratio
whether or not it was a 32:1 or 16:1 etc. machine. This oil is the
highest quality 2-cycle oil on the market today. There is no need to
have more than 1 tank of fuel for your 2-cycle equipment any more.
Do not forget to rate the answer, Thank-you
