LG Heat cool Window Air Conditioner Logo
Posted on May 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air but after 5 min it stops>
Dan Webster
Level 3:
  • LG Master 8,221 Answers
  • Posted on May 22, 2010
Dan Webster
LG Master
Level 3:
Answers
8221
Questions
5
Helped
2379100
Points
25840
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Caleb Brunson
Level 2:
New Friend:
  • Expert 54 Answers
  • Posted on May 07, 2016
Caleb Brunson
Expert
Level 2:
New Friend:
Answers
54
Questions
Helped
24201
Points
130
Sounds like the condenser is tripping and overload and resets when unit cools off after 15 min. Causes can be stopped up condenser coil, too much freon, compressor over amping from bad bearings or a bad capacitor. The contactor could be pitted and not providing sufficient voltage. The condenser fan capacitor may be weak and causing fan to shut off. Fan could have bad bearings and overheats after running causing unit to overheat which Makes real high pressures causing compressor to overamp n over heat tripping the safety overload in compressor. A good start would be make sure the fan outside is up to speed and wash the coil real good real water hose
Air conditioning not blowing cold
may have air trapped in it still or thermostat is not working properly..
A/C blowing cold air when car is cold, but clutch disengages when car heats up
Low of freon, have it charged to proper lvls with CORRECT freon/refridgerant
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Heater slow to warm up 2000 528i
Have your thermostat checked, sound like it is not working when cold.
2answers
A/c cold air stops blowing cold
Is the compressor cutting out? It could be the compressor clutch relay is going bad.
4helpful
3answers
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
1helpful
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Top LG Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
