Many bad lcd panels will show issues like this
check the menus and if theyre bad its likely a bad lcd panel
i'd complain to sony and see if they are extending the warranty for this issue as some xbr panels were defective
Testimonial: "thank you, I got it used do you think it is worth fixing "
I have a KDL-46XBR3 and want to go back to an antenna local coverage that is free. My Cox bill is out of sight. I cannot get the tv to acknowledge the antenna although I have a cable from the outside antenna installed to it.
The tv does not recognize the antenna. It shows the dvd and vcr (I guess menus) for the tv to view but does not show anything-no matter which input I use. Your help is appreciated. I have two antenna connects. The first tv works ok and shows what is local. The other tv 50' away is connected via cable to the VHF/UHF and that TV does not recognize the antenna and it is set to antenna. I have tried hooking to the CABLE hook up on the tv and there is no difference. All I can see is snow (black and white dots).
