The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
This tv unit have a colors wheel design into it.This tv problems,having loud squeling,buzzing noises or colors pictures are flashes black&white with the pictures.The tv colors wheel it is worn out and it is dying.The tv have a loud buzzing noises because the tv colors wheel it is worn out and warping out of it axis and it is spinning and hitting it steal frame box.The tv colors wheel sit way back of the tv behind many mechanical parts.Have no experience in mechanical works like take things aparts and putting it back again.Hire a tv tech. to change the colors wheel.
This set has a problem with the color wheel falling apart, which if one of the segments should fly off while the set was on it may sound like a loud pop, and the buzzing sound could be mechanical in nature with the wheel being off balance. If smoke appeared after the loud pop, then it could be a capacitor blowing in the power or video circuits. This model uses two different types of Color Wheel assemblies, either an L3 or a L6 and it would be listed on a white label on the Light Engines metal frame. Hope your solution is this easy. Bill
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner. Contact local tv repair shop to get color wheel replaced in tv. Thanks.
The tv have a colors wheel.The tv make humming,buzzing motor loud noises or flickering black and white pictures.The colors wheel is dead,require changing,bcause of the colors wheel axsis rubbing on it sides or worn out,than have black & white pictures.Hire a tv tech, to do the job.Because changing the colors wheel is not easy.Require take out many machanicals parts,before even can change the colors wheel it self.
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming ,grinding,buzzing noises.
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
If you are hearing this noises,that's your Color Wheel. The reason fot that is because your color wheel spins 5000rpms(revolution per minute) and something that modifies the balance if the disc can cause different things.Unfortunately in order to check if your color wheel is working properly you need to open your TV and physically check out.
Grinding= Most probably the color disc is broken and you need to replace it.
Spinning / Buzzing = The bearing of the wheel is loose and is loosing its balance,eventually it will brake.
The best thing to do is to take the color wheel out and spin it ,if you feel that the disc kind of wobbles or doesn't spin smoothly you have to replace it.
You can check DM they have very good prices
http://www.discount-merchant.com/SearchResults.asp?Search=samsung%20color%20whee l?click=52978 I hope this will help,please keep us posted
