Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Rangemaster 110 the clock is stuck on auto and is not letting letting the ovens ignite, can I bypass the clock?
  • 4 more comments
  • Anonymous Apr 18, 2008
    Leisure quoted me £95 to disconnect the clock!! Mine is stuck on auto too.
  • Anonymous Apr 19, 2008
    so is mine! and I have people coming to dinner!!!!
    my clock is stuck on auto - and trembling - cant activate the oven
  • FAYSWEENEY Jun 01, 2008
    Have the same problem, clock is flashing and oven will not ignite
  • awms Nov 06, 2008
    I have an all electric Rangemaster 110 and the time has just packed up. similar symptems to the other reports. The display dims when the buttons are pressed, flahses randomly and occciasionaly works after pressing the rest button- although this last a few second or an hour or so. I would like to replace the timer and it looks like they can be ordered from a number of suppliers. However I cannot work out how to get access to the timer to either replace it or check its part number. The only bit of the cooker that appears to be able to be unscrewed is the back panel. Is this the way in? Any advice or guides on how to change the timer gratefully received.
  • Anonymous Mar 12, 2014
    How do you change oven bulb on a rangemaster 110
  • 3 Answers
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Posted on Nov 24, 2008
  • UncleBrian Oct 17, 2010
    thanks fore that, we dont use the timer so disconecting it will be no hardship and the link to the instrution manual was also a great help.
    ttfn
  • Rob Hastings
    Rob Hastings Oct 28, 2013
    Solution works like a treat. Thank you tinling
I have an Aga Rangemaster 110 which was stuck on flashing 0.00 / auto too. The solution was to press the 2 left hand buttons simultaneously and then the "+" button to set the clock.
Posted on Mar 29, 2009
  • Beat89
    Beat89 Nov 22, 2017
    It worked! Thank you so much
It's very simple. When your clock is flashing between 0.00 and Auto, you need to press griller and oven buttons simultaniously once. The 0.00 should have stopped flashing. You then need to press the "-" button. If that doesn't work, press the griller/oven buttons simultaniously again so that the 0.00 stops flashing, but then press the button directly on the right, (the button that looks like a hand) instead.
Hope this helps.
Posted on Mar 14, 2009
Clock stuck on auto and cooker will n ot ignite
Posted on Nov 23, 2008
  • bear Aug 14, 2013
    'Tinling'...THANK YOU for posting your solution to 'fixing' this model!!...my ovens have not worked for two years because as a single moher of 4 I couldnt afford a 'call out'....Today, my daughter and I had a go at the simple task and now have TWO WORKING ovens MINUS a clock / timer I didnt use anyway!!!!!
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
Thanks for this folks. Re the first answer yes it's an absolute nightmare to get to the timer wiring as intimated. Took two of us to get the oven far enough out from the wall to get into the screws at the back to allow the hobs to come off. On our oven there was a protective cover over the timer so still couldn't get at the wires ! Had to then remove all the gas burner handles (they just pull off) and then unscrew the front panel - there's lots of screws underneath holding it as well. Once that was off there were the two blue wires - tadaa - only on my cooker they were both linked together already and went straight into the timer onto a spade connector. Removed them from the spade connector and that was it!! OK the clock is now blank but everything working again. Replace everything in reverse order and you are back in business. Takes a while but worth it.
Posted on Dec 11, 2014
SOURCE:
How to bypass broken clock on eurolec 720ef electric wall oven
If you bypass the clock, how will you maintain a steady temperature, include safety features, or program functions?
What you seem to want is an outdoor grill. DO NOT bypass the logic board on your oven, sir. Help Me Find My Model Number RepairClinic com
Jun 14, 2016 | Ovens Ovens
Burners work on top of stove, but oven and clock not working
Make sure the clock is not set to "auto" function or on "timer" mode. The oven will not start until the correct time has come up. If the clock is not working , this is likely to be the problem. See if there is a manual operation control or switch. You may have to get a new clock or arrange for the clock to be bypassed so the oven can work without it. Most electronic clocks can stop an oven from working if they fail.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Oven not heating but the fan is working and clock flashing auto
You need to rest the timer. to get it off auto,otherwise the oven will not work.
Refer to your instructions.
Oct 20, 2008 | Neff B1421 Electric Single Oven
Zannussi Gas cooker
make sure clock is set properly - refer to your instruction book. to test if clock is in fact faulty, access the clock and bypass it by shorting together the two wires to the clock relay
May 04, 2007 | Zanussi ZCG7550 Gas Kitchen Range
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
13,115 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
