Question about New Bright Remote Control Toyota FJ Cruiser
Circuit board design of toy car(new bright)
Do you have circuit board design of toy car(new bright? can you post the image. Thanx
Bottom screen is black and distorted
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jul 02, 2016 | Samsung Televison & Video
Where is manual control panel for brightness and color on tv
I have attached a image where the buttons are located.
You can adjust the brightness by Pressing MENU button---> Picture---> brightness.
Thanx
Jul 31, 2010 | Hitachi 42V710 42" Rear Projection HDTV
Well one of the gears in my steering motor ish area is strip;
wath brand is your car (nikko, new bright, radio shack ,etc) do you have a picture of the motor to help you to put it togheter. post it
Mar 18, 2009 | New Bright Remote Control Toyota FJ...
Forward does not work - 19.2 V New Bright Buggy
It is a problem with the circuit board. To my knowledge New Bright does not have anywhere that you can order the board.
Feb 23, 2009 | New Bright Remote Control Toyota FJ...
New bright 19.2v nicd battery problem
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
Jan 17, 2009 | New Bright Remote Control Toyota FJ...
MODEL DELL 1504 FP
I have one with no backlight. The capacitors on the board are bulging. In my opinion they were designed too close to tolerance and "cooked out". As long as it's still working change the ones in the Regulator circuit(3 in the middle of the heatsink area), and the four really small ones over by the transformers. Should be right as rain.
Aug 18, 2008 | Dell UltraSharp 1504FP Monitor
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
New Bright Remote Control Toyota FJ Cruiser Logo
389 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
